Import device programming
Hello friends.
I'm having the following problem. I have a KNX device is already programmed and parameterized, however, I precisso access this content.
Is there a way to upload the content saved on your device to change it and view it in the ETS software?
No way ... you can only send the configuration TO the device and not FROM the device.
On ETS 4 there were a special add-on that was dedicated to import a device configuration in ETS but this was a very very expensive add-on and i'm not sure that this add-on have been adaptated to ETS5
You cannot import directly from the device, but with ETS4 you can get some informations using the "info" function (right click on the device, "info" then "information of the participant with group address", or something like that)
