Nouvelle version de Linknx 0.0.1.28
Pour info jean-François a validé une nouvelle release de linknx il y a
quelques jours ...
voici joint la liste des nombreuses évolutions de cette version, fruit de
nombreuses heures de travail ...
et un lien pour la télécharger :
http://sourceforge.net/projects/linknx/f...-0.0.1.28/
merci encore à lui pour sont travail
Anthony
Release 0.0.1.28:
* Add conditional actions (skip executions of a group of actions based
on a given condition)
* Do not execute stateless rules at init (problem with object conditions
because EIBD connection not yet established)
* Avoid use of tmpfile() function in XML parser (not supported on
FritzBox)
* Allow to insert object values in some actions (shell, e-mail, SMS,
io-port, set-string)
* Add condition to compare 2 objects (requires complete refactoring of
Object and ObjectValue classes)
* Fix for exportXML with Object-Conditions without value (michael111)
* Add "toggle-value" action that will toggle value of a switching object
* Allow millisecond delays in actions
* Add "repeat" action that repeats a list of actions periodically a
specified number of times
* Add "cancel" action to cancel all ongoing actions of a rule
* Add "send-read-request" action that will force sending of a read
request on the bus
* Add attribute read="true" for listener address which is used to send
read request on the bus
* Initial schedule for timers with at and *during* fixed (michael111)
* Support for serial IO port
* Support for variable length string objects (DPT 28.001)
* Allow multiple messages in receive buffer (Mike Pieper)
* Add command to Register/Unregister all objects for notification (Mike
Pieper)
* Better command-line parameter error reporting (Mike Pieper)
* Fixes the XML for a notification message (Mike Pieper)
* Avoid linknx crash in case of mysql error
* Time-counter bugfix and 0-threshold support (Auto-Mate)
* Fix bug on x64 due to size_t != unsigned int
* Add command to query rules/timers status
* Add support for DPT 29.xxx (signed 64bit value)
* Fix TimeCounter condition not removed from timer queue when
rescheduled
"validé" me semble un bien grand mot. Disons plutôt que je l'ai
vaguement testé et que je compte sur les plus courageux d'entre vous
pour le tester plus en profondeur. C'est d'ailleurs pour ça que je
n'ai pas encore compilé de binaires pour défférentes architectures. Je
le ferai dans quelques temps, après avoir corrigé les bugs éventuels.
Jean-François
On 11 mar, 11:42, Anthony PENHARD <a.penh...@gmail.com> wrote:
> Bonjour,
> quelques jours ...
> et un lien pour la télécharger :http://sourceforge.net/projects/linknx/files/linknx/linknx-0.0.1.28/
> Anthony
> Release 0.0.1.28:
> FritzBox)
> request on the bus
> Pieper)
> rescheduled
Installé sur pogo plug sans problème avec tout (lua log4cpp et mysql)
activé. ça semble bien marcher.
Quelques nouveautés en test dont le Read dans les listener (j'avais déjà
compilé et utilisé la pré-version du 0.0.1.28 sur le CVS juste avant le
dernier ajout (* Add conditional actions (skip executions of a group of
actions based on a given condition))
En tout cas, du beau boulot
D'ailleur, comment utilise-t-on cette nouveauté:
* Add conditional actions (skip executions of a group of actions based on a
given condition)
2011/3/11 jef2000 <jef2000@ouaye.net>
> Salut,
> A+
> Jean-François
> > rescheduled
C'est juste une action avec à l'intérieur une condition et une liste
d'actions.
Bien sûr, le paramètre "trigger" n'a plus aucun sens (il est
d'ailleurs rejeté) puisque l'évaluation de la condition est déclenchée
uniquement lorsque l'action est exécutée.
Ca ressemble à ça:
<action type="conditional">
<condition type="object" id="send_notifications" value="on" />
<action type="shell-cmd" cmd="send_notification.sh $
{valeur_compteur_gaz} ${valeur_compteur_eau}" var="true" />
<action type="set-string" id="msglong" value="Light is $
{ecl_salon} " />
</action>
J'en ai profité pour illustrer 2 autres nouveautés:
1) dans les commandes shell, les e-mails ou SMS, on peut ajouter le
paramètre var="true". Dans ce cas, ${id_objet} sera remplacé par la
valeur de l'objet.
2) Une action set-string qui assigne à un objet une valeur construite
à partir de la chaine de caractère dans laquelle le même mécanisme de
remplacement qu'au point 1 est appliqué.
Jean-François
> given condition)
> 2011/3/11 jef2000 <jef2...@ouaye.net>
> > Salut,
> > A+
> > Jean-François
> > > rescheduled
#5
Je voulais savoir si on pouvait récupérer la sortie d'une command
shell dans un objet ? Ou bien il n'y a que par script LUA que c'est
possible ?
Thierry
> d'actions.
> Ca ressemble à ça:
> {ecl_salon} " />
> </action>
> valeur de l'objet.
> A+
> Jean-François
#6
Bonjour Jean-François,
Elle est prometteuse cette release !!
Je vais la tester avec grand plaisir, mais peux-tu nous éclairer
davantage sur les nouveautés ?
Désolé de t'en demander "encore (et toujojurs) plus", mais j'avoue ne
pas tout comprendre (quoi tester et comment)...
> Release 0.0.1.28:
Ok, vu dans ton post précédent.
Ca c'est la condition "if-true", non ?
> FritzBox)
N'ayant pas de FritzBox, je ne pourrai pas tester.
C'est le système de variable que tu as décrit dans ton précédent post.
A tester avec des actions de type "set-string", "shell-cmd", "ioport-
tx".
Pas compris...
Pas compris...
Action de type "toggle-value", ok.
Ok
Un exemple ?
Un exemple ?
> request on the bus
Pas compris...
Pas compris...
Pas compris...
Un exemple ?
Compris, je vais voir si je peux tester.
Pas compris...
> Pieper)
Pas compris...
Pas compris...
Pas compris...
Ok
J'ai vu les examples de Auto-mate dans le forum linknx, ok.
Ok, mais je ne pourrai pas tester.
Il doit s'agir de cet ordre xml :
<read><status/></read>
> rescheduled
Ok, j'avais suivi les échanges sur le forum linknx.
Merci et à bientôt,
Ben
#7
Installé avec succès sur 1 debian, avec lua et mysql
-----Message d'origine-----
De la part de jef2000
Envoyé : vendredi 11 mars 2011 16:56
À : domotique-EIB
Objet : Re: Nouvelle version de Linknx 0.0.1.28
Jean-François
> Bonjour,
> quelques jours ...
> Anthony
> Release 0.0.1.28:
conditions
> FritzBox)
object
> request on the bus
(Mike
> Pieper)
> rescheduled
#8
"if-true" existait déjà dans la release précedente, mais j'avais
décidé (je ne sais plus trop pourquoi) d'évaluer la condition et de
forcer l'exécution de la liste d'actions correspondante juste après la
création de la règle. Mais comme ça pose d'autres soucis, j'ai décidé
de ne plus le faire
> Pas compris...
Pour l'instant, il existe une condition pour comparer la valeur d'un
objet à une constante mais pas pour comparer 2 valeurs d'objets entre
elles. Donc je l'ai ajoutée.
Ca ressemble à:
<condition type="object-compare" id="temp_salon"
id2="consigne_temp_salon" op="lt" />
> Pas compris...
Par exemple, si tu utilise une condition sur un objet sans spécifier
la valeur:
<condition type="object" id="ecl_couloir" trigger="true" />
La condition sera évaluée à chaque fois que l'objet est mis à jour
mais le résultat est toujours "true". Et donc ça permet avec un action-
list "if-true" d'exécuter cette dernière à chaque mise à jour de la
valeur. Si l'objet possède en plus le flag "s", il sera mis à jour
même si la valeur ne change pas. Donc si tu as un poussoir qui envoie
uniquement un ON sur une adresse de groupe quand on appui dessus, tu
utilises un objet avec le flag "s", une condition comme ci-dessus et
un action-list de type "if-true" et les actions seront exécutées à
chaque pression du poussoir.
> Un exemple ?
Pour transformer ta maison en stroboscope pendant 20 secondes:
<action type="repeat" period="200ms" count="100">
<action type="toggle-value" id="ecl-salon" />
<action type="toggle-value" id="ecl-couloir" />
<action type="toggle-value" id="ecl-chambre" />
<action type="toggle-value" id="ecl-cuisine" />
</action>
> Un exemple ?
<action type="cancel" rule-id="strobo" />
Permet par exemple de stopper le stroboscope ci-dessus (supposant que
l'id dans le tag "rule" du stroboscope est "strobo").
Ca permet également d'annuler des actions qui ont été lancées mais pas
encore exécutées à cause de leur paramètre delay="..."
> > request on the bus
> Pas compris...
Si un appareil n'est pas configuré pour envoyer périodiquement la
valeur d'un objet, il n'était pas possible a linknx d'envoyer l'ordre
de lecture sur le bus (comme on pourrait le faire avec la commande
groupread de eibd). Maintenant c'est possible.
<action type="send-read-request" id="valeur_compteur_gaz" />
> Pas compris...
Si tu utilise le paramètre init="request" dans la définition d'un
objet, linknx envoie une requète de lecture sur le bus dès la première
tentative d'accès à la valeur de l'objet. La requète de lecture
utilise l'adresse de groupe principale de l'objet. Donc si tu définis
un objet et que tu ajoute l'adresse du retour d'état comme "listener",
l'initialisation utilise l'adresse principale et pas celle du retour
d'état, qui pourtant pourrait donner une info plus fiable. Donc j'ai
ajouté un paramètre read="true" dans le listener pour forcer les
requètes de lecture à utiliser cette adresse plutôt que l'adresse
principale.
> Pas compris...
C'est juste un bugfix
> Un exemple ?
Dans la section <services>, ajoute:
<ioports>
<ioport id="test-serial" type="serial" dev="/dev/ttyS0" speed="9600"
framing="8N1"/>
</ioports>
Puis tu peux l'utiliser comme n'importe quel io-port. Exemple:
<action type="ioport-tx" ioport="test-serial" data="Hello world!" />
Ou si tu veux envoyer des données binaires:
<action type="ioport-tx" ioport="test-serial" data="FF302D22A5"
hex="true" />
> Pas compris...
Si tu utilises une application qui envoie directement des commandes
XML sur le port 1028 de linknx, maintenant tu peux envoyer plusieurs
commandes en une seule opération. Avant, on ne pouvait envoyer qu'une
seule requète à la fois.
> > Pieper)
> Pas compris...
Ca aussi c'est pour les applications qui utilisent directement
l'interface XML. Elles peuvent demander à linknx de leur envoyer un
message chaque fois qu'un objet change de valeur. Ca pourrait par
exemple être utilisé par un script qui sauvegarde des infos dans une
base de données, comme ça on évite toute les complications liées au
support de mysql directement dans linknx.
> Pas compris...
Par exemple, si tu utilises la commande linknx -c house.xml (avec un
espace de trop après le -c, l'erreur rapportée était "unexpected
parameter", maintenant il renseigne au moins quel paramètre est
inattendu.
> Pas compris...
Juste un bug dans l'XML généré dans les notification dont on a déjà
parlé plus haut.
Jean-François
#9
Merci Jean-François !
Tout est clair, ma femme va adorer l'effet stromboscope, elle te
remercie déjà ;-)
Merci encore pour ton travail.
Ben
#10
Une mine d' or d informations a harder au chaud !!!
Concernant io port çela permettrais t'il de lire une interface teleinfo sur un com ?
> de ne plus le faire
>> Pas compris...
> Ca ressemble à:
>> Pas compris...
> la valeur:
>> Un exemple ?
> </action>
>> Un exemple ?
>>> request on the bus
>> Pas compris...
>> Pas compris...
> principale.
>> Pas compris...
>> Un exemple ?
> <ioports>
> framing="8N1"/>
> </ioports>
> hex="true" />
>> Pas compris...
>>> Pieper)
>> Pas compris...
>> Pas compris...
> inattendu.
>> Pas compris...
> parlé plus haut.
> Jean-François
#11
A terme, cela devrait être possible. Pour l'instant, en réception il
permet juste de déclencher une "rule" lorsque le message reçu contient
une chaine de caractère prédéfinie. Ca marche très bien par exemple
avec un récepteur IRtrans qui envoie sur un port UDP des messages
texte contenant les identifiants des touches de télécommandes.
Mis à part le fait que les modules téléinfo communiquent à 1200 bauds
et que dans linknx j'ai actuellement mis la limite inférieure à 2400,
juste parce que je me disais qu'en dessous ca n'avait aucun intérêt.
Je corrigerai ça pour la prochaine version.
Donc, mis à part ce petit détail, il devrait déjà être possible de
faire des choses basiques comme commuter qqch selon le tarif, mais pas
encore de récupérer des données comme la consommation instantanée.
Pour récupérer des données, j'imagine qu'il faudrait un système de
matching basé sur un motif définis (par ex. des expressions
régulières) et la possibilité de sélectionner des parties de messages
et de les copier dans des objets de linknx. Pas une mince affaire,
quoi...
Jean-François
> > de ne plus le faire
> >> Pas compris...
> > Ca ressemble à:
> >> Pas compris...
> > la valeur:
> >> Un exemple ?
> > </action>
> >> Un exemple ?
> >>> request on the bus
> >> Pas compris...
> >> Pas compris...
> > principale.
> >> Pas compris...
> >> Un exemple ?
> > <ioports>
> > framing="8N1"/>
> > </ioports>
> > hex="true" />
> >> Pas compris...
> >>> Pieper)
> >> Pas compris...
> >> Pas compris...
> > inattendu.
> >> Pas compris...
> > parlé plus haut.
> > Jean-François
#12
> Un exemple ?
</action>
J'ai voulu tester cela pour le fun. Chez moi, c'est pas concluant sur des
txa213 avec lampe halogenes.
