KNXWEB 2.1 - installation problem
Hi!
I was running knxweb 0.9. with linknx .32 everything fine.
Now I tried to install knxweb2. I can see the web frontend, I see parameters etc.
But when I want to change a value in "Config Knxweb" or if I want to create a new design - I either get a "loading - please wait" .. or just no reaction with nothing saved.
Looking into Apache Log I see: /knx2/design_technique.php?action=createdesign&name=default&nocache=1475001686350 ..
I tried to install all php modules - not that easy as I am running Ubuntu 16
I followed your script in setting rights and ownerships of directories ... no success.
Please help!
Thanks
Michael
There is a 'java something' option, somewhere; try to toggle it... It may helps.
Hi,
trying to change permissions on the folder "knxweb" with
$ sudo chmod 777 -R /var/www/html/knxweb2/
Anthony.
Knxweb : http://www.knxweb.fr/
Dépot des sources : https://github.com/linknx/knxweb
Version de démo de Knxweb : http://www.knxweb.fr/demo/setup.php
Script install du trio : https://github.com/linknx/install
Export ETS génère le linknx.xml : http://www.knxweb.fr/ETS/index.php
Hi!
Thanks - I tried both.
No improvement.
What browser are you using? Did you try another one?
Hi!
Yes - i tried 3
The problems remain on my ubuntu 16 with php7.... I guess there are either not all php modules installed - or a different apache behavoir.
I installed on Raspberry - everything is working fine .... according to installtrio ;-)
Michael
Hi,
for the moment, i have not testing with php7
it's probably "the" problem
look at the log file of php and send me the error in the knxweb script php
Anthony.
